It is currently 06 Aug 2026, 05:44
So what are you lot doing
by Bigplumbs » 13 Feb 2016, 17:42
Because the Cure is a new boat to me I have a very long list of jobs to do on her. I am very pleased that in my tent I have managed to get through a lot of them. Today I was repairing scuffs and scrapes in the decals. I was sad because the previous owner seemed not to use fenders much or when the boat yard lifted it in they did not seem to use them. I have done a reasonable job with a colour match that is almost there. Hope it looks ok in the daylight.
I was going to try and upload my list but I have saved it in all sorts of format but I can get it to upload. It wont even take pdf
So what jobs on the boat have you lot been up to
by Bigplumbs » 13 Feb 2016, 18:46
I forgot the obvious Copy and Paste. So here is my list not formatted
Jobs to do on the Cure before Launch Date Completed Comments Hypa Link
1 Fit Chart Plotter and new Transducer 30/12/2015
2 Refit cd Radio 30/12/2015
3 Fit new fascia to cd/radio 10/01/2016 Parts Ordered 30/12/15
4 Put Ropes on Boat 30/12/2015
5 Sort out head lining 02/01/2016
6 Seal to hatch Replaced seal and CT1 6/02/2016
7 Polish Hull 30/01/2016 Half done 31/12/15
8 Anti foul Hull
9 Anti Foul Leg - leave gap of 25 mm and different stuff to hull
10 Oil and filter change Oil and filter ordered 26/01/2016 - Pump also purchased - Delivered http://www.ebay.co.uk/itm/181606439401
11 top up hydraulic oil to stearing and PTT 30/01/2016 Oil ordered from ebay 26/01/2016
12 Refurbish mirror and refit 10/01/2016
13 Clean head lining
14 Carpet to cockpit (Mats Instead) 13/02/2016 Mats instead - Mats Bought 9/2/2016
15 Led light to main cockpit Tape wire to ss hoops
16 Make secondary mooring rope with small buoy (Take Tape for Float on Launch day) 13/02/2016 Bought and made 9/2/2016 - Just to put on boat
17 Make floating rope to mooring line Old Twat from Felixstowe said he would get the bouy, Rope bought 6/2/2016
18 Add to insurance re on a mooring was quoted £30 for year
19 Refurbish wheels if time if not in summer
20 Keep battery charged 13/02/2016 Trickel charge when at mums
21 Buy Duvet and pillows/cushions Duvet Bought
22 Plastic box with cutlery and plates etc and tea and coffee Plastic Boxes Bought 6/2/2016
23 Put on Jiggle syphon 30/01/2016
24 Backing plate behind mooreing eye bolts 20/01/2016 Materials bought 10/01/2016
25 Put boat hook on boat 30/01/2016
26 Put boat hook from wild thing onto Add to cart 23/01/2016
27 Fit USB plug near battery switch 06/02/2016
28 Flippers and dive mask and snorkel on boat Put in rear cure Locker
29 Damp collectors to engine bay 31/12/2015
30 Make sure bilge pump is working - Add water to bilge and pump out
31 Check operation of Bilge blowers
32 Remove air intakes, Paint and refit 05/02/2016 Removed 30/01/2016 - Painted 31/01/2016
33 Sort out tent pole effect to toneu cover 30/01/2016
34 Lube toneu cover buttons 30/01/2016
35 Check operation of camper cover zips again - refit camper cover
36 Restich parts of camper cover Nov-15
37 Put fenders on boat Nov-15
38 Leave small sea plane and TX on boat - Not lipo
39 ? RC boat on boat
40 Tighten/mg hole for screw for table and boarding ladder Boarding ladder done 5/02/2016
41 Check all over for loose screws
42 Tool kit for boat incl fuses
43 Small blow up boat put on board with paddels 13/02/2016 Boat Purchased 31/1/2016
44 Fix Trailer poles from Wild Thing
45 Fit chart plotter mount and power cable to Add to Cart Not sure if one will fit
46 Measure the size of the lockers 30/01/2016 Side Locker Opening 530 x 230 mm Floor opening 500 x 255 mm All very large lockers
47 Ropes for end of Toneau cover
48 Repair to stickers on sides 13/02/2016 Vinyl bought 6/2/2016
49 Repair small dings in gell coat about 6 locations 05/02/2016
50 Buy anti chafe device for mooring rope http://www.seamarknunn.com/acatalog/spi ... html#SID=9
51 Petrol/water filter change Bought ebay 6/02/2016
52 Put 2nd fishing rod on boat
53 Add small float to bow roller pin 05/02/2016
54 Test Fit location for 2 of the Black 10 ltr Fuel cans 05/02/2016 Will fit fine
55 Put Shore Power lead on board 05/02/2016
56 Plastic Rearly Usefull boxes for lockers 2 No Bought 5/2/2016
57 Hold All for boat 05/02/2016 Bought 5/2/2016 but at home
58 Mastic to top of rub Rail 06/02/2016
59 Save up lemonade bottles as water bottles for boat
60 Rope ladder for access 13/02/2016 Bought 5/2/2016
61 Grease rust on stearing lines 06/02/2016
62 Oil leak at Fuel Pump 13/02/2016 It turned out to be Hydraulic oil from Steering resvoir
63 Buy oil for leg and top up 13/02/2016
64 Check over winch and oil/grease 13/02/2016
65 Think about second battery
66 Extension to mooring ladder
by sprocker » 13 Feb 2016, 20:00
Blimmin 'eck Dennis, that's what I call a list!!!
I'm interested to know what you do with your spare time.........
I'm afraid my list is a little shorter:-
1) Service Engine
2) Antifoul
3) Wash and wax
by Bigplumbs » 14 Feb 2016, 09:41
sprocker wrote:Blimmin 'eck Dennis, that's what I call a list!!!
1) Service Engine
2) Antifoul
3) Wash and wax
I Know but this is a new boat for me and many of the items are one offs and some are but a few seconds to do. I also now have a separate list for the engine and there are quite a few items on this. The manual I downloaded is very good indeed
Also there seems to be a lot more to do engine wise on a 4 stroke inboard with leg than on a 2 stroke outboard
by BruceK » 14 Feb 2016, 09:42
This time of year I get my gardening fix out the way.
by Bigplumbs » 14 Feb 2016, 09:53
I now have a separate list for my engine... God this manual I downloaded is good
10 Engine oil and filter change
E1 Check all Anodes
E2 Check height of hydraulic oil in power tilt and trim kit
E3 Check for Grease nipples on power steering cables If any add greese
E4 Check tightness of belts 6 mm
E5 Oil pivot points on all throttle and gear shift, and steering joints
E6 Check for any water in oil at leg fill/drain and quality of the oil
E7 Remove and clen out flame arrestor/air filter as I would call it
E8 Spray engine and stern drive with WD40 FROM TIME TO TIME
E9 Keep all holes on sterndrive (as page 97) clear of crap
by ColinR » 14 Feb 2016, 17:04
Watch the rugby, wait for the weather to improve, fit new fuse in the aux circuit, refit all of the stuff that is at home to keep dry then go boating.
by TorbayRob » 14 Feb 2016, 20:09
BruceK wrote:This time of year I get my gardening fix out the way.
Wow! Most of my garden is underwater, so I guess I should be getting a double fix? :roll:
I have a new bow tank, deck filler and breather to fit to the little Fletcher, plus a good clean, brake overhaul on trailer and a few odd and ends... The project Arrowbolt list would be a book, so won't go there for now - except to say another 10 years should just do it! :lol:
I started a new job last week as a service coordinator for a local marine services company and marina - so a dream job! 'Downside' is a staff discount and credit account at the chandlery, so given my lists are long I need to be careful I don't spend more than I earn!
TorbayRob
by sprocker » 15 Feb 2016, 08:07
Dream job indeed Rob!
Is that local to us?
by BruceK » 15 Feb 2016, 12:11
By gardening fix I mean denuded. Cut back and empty out. I live in a forest conservancy so no imported species etc. and all natural. But a cut back now saves on the summer headaches and boating time.
