It is currently 21 Jun 2026, 11:31
Tow Bar Extension for launching
by Bigplumbs » 31 May 2017, 08:51
The main slip I use is a little shallow and I want to try launching and recovering my 17 foot bow rider on my own. I need to increase the length of my tow bar for launching and recovery only. Not for towing as it tows nicely balanced as it is.
I have found simple bars with a tow ball one end and a hitch the over but these give no steering at all.
I would like something like the attached pic and have googled around but cant find something similar in the UK. Anyone done this or know where I can get one. If not I will have to try and make one.
by sprocker » 31 May 2017, 09:11
A chap launches in Torquay with an extender made from scaffold pole with a towball welded on the end. (Doesn't want to get his car wheels wet).
He then has three U clamps welded to his trailer A frame that the scaffold pole slides into and clamps up when he wants to use it.
Very simple, effective, and cheap.
by Bigplumbs » 31 May 2017, 10:18
sprocker wrote:A chap launches in Torquay with an extender made from scaffold pole with a towball welded on the end. (Doesn't want to get his car wheels wet).
Yes I saw that option but I have a thing in the way under the tow bar
by BruceK » 31 May 2017, 11:25
If you create the drawings most trailer fabricators will make you one. I was quite pleasantly surprised when I was modifying a American trailer to make it UK VOSA legal that they were quite happy and eager to take my custom for 1 off pieces and at prices that I thought were very fair.
by Bigplumbs » 01 Jun 2017, 06:42
BruceK wrote:If you create the drawings most trailer fabricators will make you one. I was quite pleasantly surprised when I was modifying a American trailer to make it UK VOSA legal that they were quite happy and eager to take my custom for 1 off pieces and at prices that I thought were very fair.
I have managed to find most of the parts I need at home and also from 2 old scrap cars I had (I seldom throw things away). Mine will use ball hitches to hold the tow bar in position when not in use and I can cannibalise an old winch for a bracket. And believe it or not I have a long piece of galvanised box section from when I made my poles for my trailers. If these parts work all I need is the actual hitch which I think are about £20.
Now I am not working I like to try and make things myself if I can.
by betty boop » 01 Jun 2017, 07:30
Be carefull Dennis, it's very easy to get over come by all these little boat projects and forget about looking for work/working. I speak from experience :lol: :oops:
by Bigplumbs » 01 Jun 2017, 11:18
betty boop wrote:Be carefull Dennis, it's very easy to get over come by all these little boat projects and forget about looking for work/working. I speak from experience :lol: :oops:
I have some work which will see me ok for now I am not going to look for anything proper until the end of the year. All the young ones seem to have a year out so so am I :)
by Bigplumbs » 01 Jun 2017, 11:19
Here are the parts I have scraped together
DSCF8755 (Medium).JPG (390.21 KiB) Viewed 16531 times
by betty boop » 01 Jun 2017, 12:31
yeah I hear you - my year out has fallen into desperation and lasted 2 1/2 years so far on and off. If any of that work can b spread around let me know ;) :lol:
by Bigplumbs » 02 Jun 2017, 15:09
Well I have been on and off this job for a few hours doing other things but it is working far better than I thought particularly as I scavenged 90 % of the parts. Total cost will be £15 excluding the bits I had. This is the hitch and some bolts.
Here are some pics nearly finished.
You will see that I have clamped the hitch ball to the trailer so it is adjustable and also so I did not have to grill the trailer as it is galvanised and don't want to introduce a rust point.
The bracket is made from an old boat winch I had and the tow balls were from scrap cars I had in the graveyard.
All I have to do now is fix the hitch and adjust the ball on the trailer to suit the length I finish up at.
I think this will work quite well and will give me that vital 1400 mm ish more I need so I can drive the boat on and off with it still on the Discovery and keep the car out of the water
DSCF8760 (Medium).JPG (375.86 KiB) Viewed 16498 times
DSCF8759 (Medium).JPG (326.7 KiB) Viewed 16498 times
DSCF8758 (Medium).JPG (323.55 KiB) Viewed 16498 times
DSCF8757 (Medium).JPG (325.3 KiB) Viewed 16498 times
DSCF8756 (Medium).JPG (273.3 KiB) Viewed 16498 times
  • In total there are 2 users online :: 1 registered, 0 hidden and 1 guest (based on users active over the past 5 minutes)
  • Users browsing this forum: Bing [Bot] and 1 guest
