It is currently 21 Jun 2026, 12:58
Outboard problems
by NickG » 07 Mar 2017, 09:06
Hi I have a 1978 Johnson 6hp outboard. It ran fantastically until the gear linkage came apart. I reconnected it and put it back together. It started and ran fine but I notice it wasn't pumping water anymore. Have I missed something or missed a connection ? Any help greatly appreciated
NickG
by shibbs » 07 Mar 2017, 17:34
Was it run in salt water? If so how long was it sat without running?
May have a salt build up?
I had to strip my 2.2 down completely because of this.
May be an option and just coincidence?
by NickG » 07 Mar 2017, 19:50
No it was serviced had some some new parts and run in fresh clean water for 10 minutes ! After a full day of research I think it might be the water tube that goes into the top of the water pump ( it might not be in properly) !
NickG
by Bigplumbs » 07 Mar 2017, 22:18
I suspect that when the work was done on the selector the pipe was not connected properly.... Easily done
by NickG » 07 Mar 2017, 23:32
Well I will take it all apart again and try again to reassemble it correctly once again thanks for the advice hopefully I will mend it for the last time (well this time ) !
NickG
