It is currently 21 Jun 2026, 12:50
Season start?
by sprocker » 19 Feb 2017, 21:28
ChrisH wrote:And don't forget at the beginning of the journey stay in the channel as you leave the Hamble River. Dont be tempted to cut across to your starboard.
Good point. That 'shortcut' was pointed out to me when we did our sea trial, apparently quite a few have tried and failed.
by betty boop » 22 Feb 2017, 18:46
been there done that, luckily it was very clear water and I quickly realised my novice mistake before it was too late. never done it again even at high tide. :lol:
by ChrisH » 26 Feb 2017, 11:56
I'm tempted at high tide. Pretty sure the charts show plenty of water. But too scared.
by NickT » 26 Feb 2017, 15:29
I've done it!
Yes, you need a rising high tide and probably an outboard rather than stern drive. Don't even think about it if you have shafts.
A 20ft boat is probably the biggest I would take over the shingle - go slowly and keep an eye on the depthsounder - 3ft below the transducer is the minimum.
I have also used the shingle bank to rest a while when it was foggy before venturing out onto Southampton Water.
Nothing is sacred though, once the fog had lifted I set off and the harbour master came alongside and enquired if I was OK as some fishermen had reported seeing a boat on the spit....
by ChrisH » 27 Feb 2017, 22:28
NickT wrote:I've done it!
Like.
