It is currently 21 Jun 2026, 13:38
by BruceK » 05 Oct 2016, 11:39
by argonaut » 05 Oct 2016, 12:56
ChrisH wrote:
argonaut wrote:Sort of returning to the OP
My jerry cans have an air release valve in them so they empty really quickly and smoothly. I had a quick look for a link but could not find one. Will post if I find it. Highly recommend them.
I have 2 20 L cans .... neither have an air release valve - so both air lock and make emptying pretty slow.
If you find teh details please sens them through.
by ChrisH » 05 Oct 2016, 18:39
Here you go this is what I have.
Not sure if this is the only place you can get them. But the air valve makes a massive difference.
http://www.jerrycans.co.uk/20-litre-aut ... -254-p.asp
betty boop wrote:for Argo - why the forum won't allow a jpg on a PM is a bit weird .
by argonaut » 05 Oct 2016, 19:25
by betty boop » 05 Oct 2016, 19:32
hijacking this post a little but any recommendations on an oil change pump? at the lifeboat we used to have a little pond pump made up to run on 12v but I can't remember if it had a tube down the dipstick or fastened over the dip hole. Ebay has a few cheapie's so probably not worth making anything and I really don't want a manual pump 'pump' to unless they are the best thing?
by argonaut » 05 Oct 2016, 19:39
Plenty on sale on eBay
  • In total there are 45 users online :: 0 registered, 0 hidden and 45 guests (based on users active over the past 5 minutes)
  • Users browsing this forum: No registered users and 45 guests
