It is currently 21 Jun 2026, 13:38
by NickT » 04 Oct 2016, 13:28
+1 for a jiggle tube.
Just bought one and now I don't have to bend over the side of the boat with a 10kg weight of fuel while trying to fit the spout in the filler.
Best purchase on boat for a while!
by BruceK » 04 Oct 2016, 14:58
I've been following this thread for a while. I have a jiggle syphon and a inline fuel pump onboard in a locker from the PO. God knows why though. The last post broke my silence. What you moaning about 10kg?! If the PO of my boat did indeed use these devices he must have been one hefty bugger doing a ton of diesel each throw. :lol:
by NickT » 04 Oct 2016, 20:53
Hi Bruce,
10Kg at full arms-length whilst leaning over a windscreen to get to a filler tube halfway down the freeboard on a Fletcher Sports Cruiser without tipping half of it into the Hamble is tricky.
You can come and fill my boat up with 8 cans full if you think it's that easy! :D
by ChrisH » 04 Oct 2016, 22:40
argonaut wrote:Sort of returning to the OP
My jerry cans have an air release valve in them so they empty really quickly and smoothly. I had a quick look for a link but could not find one. Will post if I find it. Highly recommend them.
My jerry cans have an air release valve on them so they empty really quickly and smoothly. I had a quick look for a link but could not find one. Will post if I find it. Highly recommend them.
by ChrisH » 04 Oct 2016, 22:42
NickT wrote:Hi Bruce,
I'm lucky my filler cap is on the stern accessible from my swim platform. Still have to lean over a bit but it sounds much easier than you have to put up with.
by betty boop » 05 Oct 2016, 08:09
for Argo - why the forum won't allow a jpg on a PM is a bit weird .
by betty boop » 05 Oct 2016, 08:18
betty boop wrote:for Argo - why the forum won't allow a jpg on a PM is a bit weird .
having posted that Ive looked on eBay and there are warnings not to use any of these pumps for transfer of PETROL. be warned .
by BruceK » 05 Oct 2016, 08:26
:lol: It was a tongue in cheek comment. Because the Formula is mostly a petrol powered boat the diesel conversion leaves her with huge tanks for her size. What I was alluding to was is the ability to top up your tanks from a jerry can is a nice problem to have.
by argonaut » 05 Oct 2016, 10:35
Thanks for pic of the article ....
I did look at the pumps and not suitable or Petrol
There are petrol pumps ... but flowrate is too slow (engine fuel pumps)
  • In total there are 41 users online :: 0 registered, 0 hidden and 41 guests (based on users active over the past 5 minutes)
  • Users browsing this forum: No registered users and 41 guests
