Brake service
by argonaut » 04 Jan 2015, 12:12
On the previous forum during a thread on servicing brakes, one member posted some pics where he had painted back plates black.
Anybody now on this forum want to own up ?
Interested how paint faired, and what it was.
Could give mine a painting at annual pre-season brake service.
by Ianfs » 04 Jan 2015, 17:09
Argo, I've had a good look and I think the only posts about painting trailer suspension was me.
I did mine a few years ago. My trailer is a lot older than yours and had taken a real pasting.
Rusted Suspension.jpg (164.16 KiB) Viewed 26849 times
So I decided to experiment with what was supposed to be the right paints. First, primed with Hammerite Rust Killer.......
Axle and backing primed.jpg (83.23 KiB) Viewed 26849 times
Then Hammerite Silver....
Axle and backing painted.jpg (99.34 KiB) Viewed 26848 times
However I think it was you who advised a few years ago that Hammerite cured by evaporation, which meant that it shrank and would be prone to cracks and let in air, which in turn would cause oxidation.
Consequently, I stripped it all down 2 years ago and used a Resin 2 pack paint and have dunked it many times since without a problem.
Hope this helps.
by shibbs » 04 Jan 2015, 17:20
I may be wrong but I seem to remember AndyB also doing it?
Think he left a while back though?
by argonaut » 04 Jan 2015, 17:42
This was not the pics ... it was last year ( I think) pics showed gloss black paint on the backplates of the brake assemblies.
I did post that Hammerite is not good for trailers, Smoothrite is better ...but still not as good as acid etched primers then a 2-pack paint.
by Ianfs » 04 Jan 2015, 18:01
I've had another look but can't find anything.
However you may be interested that having completely cleaned all the bad paintwork and then de salted with X Salt, I painted the hubs and back plates as well as the suspension units with Epoxy Mastic, a 2 pack paint which cures by Chemical reaction rather than evaporation.
This was two years later after several dunkings in Salt water, but having been stripped and cleaned.
Epoxy Mastic coated.JPG (153.41 KiB) Viewed 26843 times
by argonaut » 04 Jan 2015, 19:27
Who makes that paint.?
Separately ... is the history from old site going to be added to this ..
Some good information there.
by Ianfs » 05 Jan 2015, 18:24
High Argonaut. Sadly we worked hard to try to get the information back to some sort of working forum after it had been attacked and very strangely some of the data base had been deleted. In short we cannot transfer the information.
Back to the Epoxy Mastic, its made by these guys and I'm told the RNLI use it on their Sea Tractors, but don't have any proof.
http://www.rust.co.uk/epoxy-mastic-rust-proofing-paint/c28117/
HTH. :)
by argonaut » 05 Jan 2015, 19:46
Pity about loss of data ... didn't you have any backups?
Only ask as I wrote up several launch sites & a couple of projects.
by Ianfs » 06 Jan 2015, 19:44
The old site was owned by CSL and still is. We did take back ups but didn't have access to the root directory until recently. However somehow the root directory was hacked and a lot of the database deleted maliciously.
Anyway I've learned a lot from it and now we have back ups every night without fail and a very secure future.
So post away, I won't let it happen again, Boat Banter is here to stay.
by _Ed_ » 06 Jan 2015, 22:59
argonaut wrote:Pity about loss of data ... didn't you have any backups?
I know that feeling :( Upwards and onwards!
