I am very very confused about the weather this weekend. I'm even more confused about the weather we have had despite the fact that it's October and we were advised 2 months ago that an Indian summer was due .
I have to say that I don't understand forecasts and how they are made, but I do think that some of them are made to our advantage and that some might not be as accurate as we might think. Some, on the other hand are made for us to think the worse and then when its not as bad we feel good.
But then when we see surface pressures from the Met Office for Saturday with Isobars so far apart, wind speeds should be low .............
- 28188670.gif (124.97 KiB) Viewed 14343 times
You would then think that Ed's schematic with pale green in the Solent and winds of ENE, which are quite important in the Solent area would, although wind speeds are 16--20mph would give wave heights of 1m or less or at least a nasty chop. But then if you drill down into it there are sites predicting this, which make a lot of sense, local more condensed low pressures.............
- uk_spchart_current.jpg (108.74 KiB) Viewed 14343 times
If I lived in the Solent area, it would definitely be a poke my head out and wait and see!
