Volvo Penta Duoprop
by argonaut » 09 Jan 2022, 22:50
OK … after some help.
Anybody here own a VP with DPS DuoProp drive ?
If so do you by chance own the front prop removal tool. pn 3862797
It is damn expensive for a piece of tube with 3 notches cut in it.
Looking for someone who has the tool and could confirm dimensions.
by Ianfs » 10 Jan 2022, 09:58
Are you going to make one Rick?
I may know someone who could get the dimensions for you.
by argonaut » 10 Jan 2022, 11:16
Yes .. not exactly a complicated tool .... certainly better than paying
VolvoPenta tool 3862797 there are several variants.
What I need are length, OD, ID and width and depth of one of the slots.
Prop Tool.jpg (169.6 KiB) Viewed 20422 times
by Ianfs » 10 Jan 2022, 20:29
I'll see what I can do. :)
by ian h » 10 Jan 2022, 21:02
I have both these for sale . Only used a couple of times and then boat sold,
Inner Prop Removal Tool - Genuine
21318669 on Key Part for £20.40
873058 tool kit £77.54 on Keypart.
Sensible offers
by ian h » 10 Jan 2022, 21:15
argonaut wrote:OK … after some help.
Just looked up the price and that's silly money they are asking,
by Ianfs » 11 Jan 2022, 15:05
Hi Rick, really sorry but I couldn't help.
There are plenty of these at not much money ..............
Prop removal tool
But not the same part no. They are massive though and there are a few Youtube vids as well.
As you and Ianh have both said the prices for the one you require are ridiculous.
They look like they are made out of 2" pipe. I suppose you could always take of the rear prop and measure the nut diameter and if you need 3 slots divide the circumference into 3 and cut holes to fit.
I suspect I'm teaching you to suck eggs though. :D
by argonaut » 11 Jan 2022, 22:37
There are several variants of DuoProp …. THE PN I gave suits my drive and several others, but unable to tell if other pn’s will work.
by Ianfs » 13 Jan 2022, 08:20
I agree they all look a little different in the pictures don't they.
I still think that it may be a good idea, whilst the weather is miserable, to remove the rear prop then get the dimensions of the nut with the position of the slots. It also looks like you may have to put a small weld in as well. The one you showed also has what looks like pins attached as well as slots.
by argonaut » 13 Jan 2022, 14:49
ian h wrote:I have both these for sale . Only used a couple of times and then boat sold,
Sensible offers
For the Inner prop removal tool .... are you able to measure the ID and OD
I now have the correct dimensions ..... if yours would fit then I 'd buy.
