It is currently 21 Jun 2026, 08:47
Lighting board parts
by mlines » 26 Mar 2015, 14:04
The answer is in your own post......
If it is visual it shall be a flashing light which, at least in the event of the malfunction of any of the front or rear direction indicator lamps, is either extinguished,
That's what mine does.
The change in click is only required if it is an auditory only system
If it is entirely auditory it shall be clearly audible and shall show a marked change of frequency
And you should see the rather smart LED markers my trailer had fitted :D
by argonaut » 26 Mar 2015, 14:11
My answer is in my post ?
Not sure what you mean here, what question do you think I asked?
by mlines » 26 Mar 2015, 14:24
I said in an earlier post that my click did not change.
You said in the post on the directive that the click MUST change.
However the directive included those statements that I picked out that says it only has to change when its the only warning. The trailer light extinguishing (which is what mine does) is listed as a valid warning.
Martin
by argonaut » 26 Mar 2015, 16:27
Then I'm not following you .. as the warning device does change which was my point.
But never mind the purpose of this threads is to find light parts ... and so far had 8 suppliers respond and said no ......... so looks like I can't get the LED lights that are 'front' mounting
by Carl » 26 Mar 2015, 18:42
Reverse lights are not a legal requirement for trailers. ...
by argonaut » 26 Mar 2015, 20:05
Realise not a legal requirement .. but would be useful ... and new 13pin plug allows for reversing connection.
by betty boop » 27 Mar 2015, 08:45
Just like the last topic on the old forum. When will we start to argue over Iphone vs Android again ? :lol: :lol: :lol: :lol:
by argonaut » 27 Mar 2015, 10:09
There is no argument here ... 13pin 'is' the new Euro standard.
It is a technically far superior plug.
Of course you can still fit 12S & 12N, but as there is a new better product, I decided time to move on ( esp as I also need new lighting board)
The 12S & 12 plugs are very poor connection, with no interlock. Having spent many a time having to repair or replace these plugs, have personal experience of this.
The new 13 pin is a very positive twist lock lock plug & socket.
At present you can of course still use the old style plugs, but at some point it will become illegal to fit old style sockets to new cars.
On my last car you could only have a factory fit 13pin option ... with an adapter for older plugs.
Once more & more fit 13pin as standard, the use of 13 pin will become the 'norm'
You could equate it to the old style caravan gas bottles, for years people still used screw on fittings &:spanners... even though quick fit newer designs existed.
Both achieved the same result ... even though one was an improved better solution.
It took a while, but when all caravan manufacturers fitted quick fit as standard, eventually everyone changed.
Now you hardly ever come across old type.
2" tow balls went same way, old 2" balls existed alongside 50mm for years .. even though they were illegal to use (or even to have fitted) with added safety implications that you could mismatch ball & hitch.
The same will happen with sockets.
I held out for a while, decided that advantages now outweigh disadvantages..
by Carl » 27 Mar 2015, 14:44
Yup ... can see where the 13 pin sockets would be useful. ...
Now then ... about that "android vs Apple" debate ... :lol: :lol: :lol:
by argonaut » 27 Mar 2015, 15:09
Go buy a windows phone :-)
