It is currently 21 Jun 2026, 10:32
OK the dreaded weekend
by argonaut » 18 Nov 2018, 17:59
Given up for the year ... engine & drive annual service & winterised.
Full polish of hull today ... it is gleaming in the sunshine.
Jack up boat to ensure polished under rollers of trailer.
Dehumidifier in, condensate pipe out through transom drain, seats propped up to allow airflow, same for hatches etc.
Stabiliser in, fuel topped up.
Tower off ... standard covers on, plus overall cover.
Trailer put on axle stands.
Satisfaction that it looks perfect .. not a ingle scratch on hull .... sadness that another year gone.
Just finished polishing the prop, and boxed it up.
Now just have to wait for April.
by shibbs » 18 Nov 2018, 18:44
A lot of work.
Satisfying when done though.
I was supposed to be doing the same this weekend but car problems prevented. Planned in for next weekend now.
by argonaut » 18 Nov 2018, 19:34
Did it this weekend as cold weather forecast... needed engine winterised.
by ChrisH » 18 Nov 2018, 23:23
Moving to a my new mooring this weekend with power . Plan to order 2x tube heaters and a dehumidifier to drain into sink. Hope this will keep everything in good shape this year.
by sprocker » 19 Nov 2018, 14:08
I have a 5' Tube heater that I no longer need, free to good home if you can collect. Has inbuilt thermometer.
by ChrisH » 19 Nov 2018, 14:33
sprocker wrote:I have a 5' Tube heater that I no longer need, free to good home if you can collect. Has inbuilt thermometer.
Oh cool. V interested...Where are you?
by argonaut » 19 Nov 2018, 14:47
If you are installing a dehumidifier you don't need heaters as well (as long as its not a compressor type)
by ChrisH » 19 Nov 2018, 18:14
argonaut wrote:If you are installing a dehumidifier you don't need heaters as well (as long as its not a compressor type)
Hmm ok. I thought it would help with air circulation and keep air temps above freezing if it gets really cold? Does the dehumidifier put enough heat out to Do this itself?
by argonaut » 19 Nov 2018, 18:56
With a compressor type dehumidifier it’s important to keep warmer as they do not work well at low temp.
The revolving disc type work far better at low temperatures.
They do put out some warmth ... but it is about lowering moisture in the air not the temperature.
I have used one for several years ... work really well.
In first few weeks it takes loads of water out several litres a week.
No need to set rh too low, and I just leave mine on auto ... comes on only when needed.
