It is currently 21 Jun 2026, 09:04
2 Stroke Winterisation
by Bigplumbs » 03 Dec 2017, 08:07
When I first came to this forum I worried quite a lot about winterising my outboards which are 2 strokes. Now I do nothing to them perhaps put some fuel stabiliser in the petrol tank.
So what do other do to their 2 stroks because I basically think that there us nothing that needs doing
by NikTheGeek » 04 Dec 2017, 08:49
I don't even bother with fuel stabalisation :) I just run it up on the muffs or at the local lake every now and again...
Seadoo Spark (for now)
ʞǝǝbǝɥʇʞıu/ɯoɔ˙ɹǝʇʇıʍʇ
ɹǝzʇןǝɯsʞıu/ɯoɔ˙ʞooqǝɔɐɟ
NikTheGeek
by argonaut » 24 Dec 2017, 21:10
I did do a post on 2-strokes on previous forum.
I drop gearbox, change water pump impeller, top up oil, grease all appropriate parts.
Spray water dispersant over everything under the hood (while all still warm)
Change in line fuel filter/separator.
Remove prop.
Cover shaft & lower gearbox with plastic bag to prevent bugs/dirt entry.
Insert wood block to hold weight of engine ...rather than on rams.
Take battery off and put on soak charge.
Spray all electrical connectors & plugs with ‘Corossion Block’. (marine ver of AC50)
by Doc Oakley » 12 Aug 2018, 12:58
Hi all - just wanted to expand the debate on fuel stabilisers - last year, my 2012 E-Tec 25 cost me an awful lot of money for a new vapour separator and high-pressure fuel pump...the dealer told me that due to what's in fuel these days (I can't recall whether it's more or less ethanol) leads to the sort of failure I experienced: apparently this is common...every week this dealer is doing this sort of work. There are two other possible causes 1. I ran out of fuel - well, actually the fuel line was not connected - schoolboy error in a rush to get out 2. I didn't actually winterise the motor the year before - I should point out the boat is kept in a heated garage.
Overall hours at the time of the breakdown in 2017 less than 30...
This year, thanks to the good weather, I've put another 30 on so far without a problem.
So, minded now to do proper 'pre-flight checks' and to always winterise, do people think that things like the 2+4 additives are worth it, or even necessary?
Simon.
Doc Oakley
by argonaut » 12 Aug 2018, 13:42
This would only be an issue if using E5 or E10 Ethanol fuels. ( common in US)
There are not used on forecourt pumps in the UK (at least not yet)
So no risk of damaging your engine.
I think the background to Ethanol fuels is manufacturing of Ethanol from crops (not oil) .
