It is currently 06 Aug 2026, 04:17
Blwyddyn newydd dda pawb.
by argonaut » 02 Jan 2016, 20:06
I noticed a broken fitting on my deck .. where a wire passes through the hull ........... anybody know what these are called, so I can get a replacement :
by ian h » 02 Jan 2016, 22:36
here you go
https://www.google.com/search?q=transom ... 24&bih=489
But can not find a UK supplier
by Bigplumbs » 03 Jan 2016, 08:10
It is odd because I fitted one of those the other day when I fitted my transducer. But I searched and could not find one to buy
by shibbs » 03 Jan 2016, 08:42
Might be worth a quick email to the manufacturer? Sure with that picture they would send out a replacement..?
by sprocker » 03 Jan 2016, 10:26
May not work for you but I replaced a couple of broken cable covers on my old Bayliner with these.
http://www.force4.co.uk/index-marine-side-entry-cable-gland-for-2-7mm-cable.html#.Voj21bKnzMI
by Gazjen » 03 Jan 2016, 21:06
There's a couple of transducer mount kits on eBay that have them included.
Gazjen
by argonaut » 03 Jan 2016, 23:40
Pictures are nice ... but don't help with buying one :-)
I had seen the side entry items in Force4 catalogue .. a bit bulky.
Can't go to boat manufacturer as this was after market item .........nav lighting on Wakeboard tower ......... will have to contact Wakeboard Towers UK.
Thought they might have been a common item.
by ColinR » 04 Jan 2016, 10:41
I picked one up from my local Force 4. I cannot remember how much it was but I'm sure it was worth it!
Mind you I went posh and got a chrome one :lol:
by BruceK » 04 Jan 2016, 15:32
That looks much like a mercruiser trim sender's thru-hull cable guide. I'd try Holesbay Marine if it is
by Bigplumbs » 04 Jan 2016, 18:27
I know what my old dad would say.................... If you cant buy one boy codgel summit up
