It is currently 13 Sep 2025, 11:08
Yanmar 3GM30F V Pulley cold-start
by Malc » 22 Mar 2018, 23:38
Hi all,
What thread size are the four bolts that can connect to the crank-shaft V pulley on a Yanmar 3GM30?
Boat had been stood for awhile and I'd like to practice hand-cranking the engine. However, no dedicated connection point for the cranking lever like some models. It can be done by cranking the crank-shaft V pulley direct so my plan is to insert two bolts into the pulley and use them as leverage to rotate the crank-shaft.
Thoughts welcome as well.
Regards
Malc
Malc
by Ianfs » 23 Mar 2018, 10:08
Probably one of the most fascinating questions we have had. :)
I doubt anyone will know the answer to this one, but I'm hopeful that someone with more engineering knowledge than I might provide a solution. I'm assuming there are only threads in the pulley at the moment?
This may help a little, I couldn't upload the PDF so you'll have to view it online.........
https://j109.org/docs/Yanmar-3GM30-parts-catalog.pdf
I suspect you are way ahead of me but undoubtedly, as its a Japanese engine, they will be metric, so maybe a guess at the size?
by Malc » 23 Mar 2018, 16:48
Thank you. Very useful. I don't know if the idea will work but a least it will allow the rotary parts some movement. Once again thanks
Malc
by Malc » 23 Mar 2018, 20:05
Looking at the pdf, the bolt sizes might be the same as the coupling flange on the transmission.
Malc
by Ianfs » 24 Mar 2018, 08:37
Some useful info there then. Worth a try with one at least. :)
