So do most peope.have the transom forward of the rear rollers then?
No, most are just like yours.
Right well, if I've got the bits in the picture right, you should be able to move the rear swinging arm forward a short way in order to move the boat a little further forward. You may need to either scroll down the photo or open it up.
There is one further consideration to take into account, which I have just remembered towing a twin axle trailer with a saloon/estate car and that is the tow ball height. A Land Rover, for example has a higher ball height and therefore the trailer sits more naturally when attached with both axles taking the same load. When I towed with a BMW, the natural sitting position of the hitch was about the same as the tow ball, consequently very little downforce and extra load on the front tyres.
I'm sure I read in one of your posts that your front wheels are taking more weight than the rear, is that right or am I dreaming?
Oh and a quick tip, buy a cheap set of bathroom scales and stick them under the jockey wheel.
- Chris's boat.jpg (181.42 KiB) Viewed 23554 times
