Mixed 50/50 with water. Is that ok
Hi Dennis
As far as I know the Blue antifreeze should be fine. I’m sure you and others know more than I about this, but there are two types of antifreeze out there for car engines (closed cooling), one is Blue for engines before 1998 (IAT Inorganic Additive Technology) and the other is Pink, for engines after 1998 (OAT Organic Acid Technology). Ethylene Glycol the main ingredient doesn’t go anywhere but the additives do, additives are the anticorrosive stuff. Blue is supposed to last 3yrs and Pink 5 yrs, but you are not supposed to use the OAT Pink stuff in earlier engines and visa versa, something to do with seals and metals used, but not sure.
Raw water cooled boat engines and the life expectancy of antifreeze is down to when we empty it out, i.e.3- 6 months, plus Mercruiser engines have not changed as much as car engines so a 1998 engine would have earlier technology. I have used Blue antifreeze for a long time and have not seen any ill effects in raw water cooled engines. In fact I would expect pumping sea water through the block would have a more corrosive effect.
The most important thing to remember is where you live and has the Winter temperature ever reached a seriously low level i.e. -30, I strongly doubt it. So if you live in an area with moderate Winters as I do, in Sussex, then -20 is well enough for peace of mind, especially when you see the temp dropping to -10 etc. as we did one year, but most of the time its only about -2 to -3c.
As Anna said, always store you boat with the leg down, less strain on the bellows. Also as Ian has said, if you pour the mixture down the intake tube, the long one leading up from the Transom Shield inside the boat, it will drain down into the leg and you'll see it coming out when there is enough in there.
As regards how far you go with Winterisation, that all depends upon how much you know about the Bellows, Impeller and Gimbal Bearing .
As a bare minimum, change the oil in the leg, engine, change the plugs, fog the engine and add anti freeze. I found this last night, if it's any good to you?
- 3.0 cooling system.jpg (268.48 KiB) Viewed 15849 times
