It is currently 20 Sep 2026, 01:11
Volvo Penta Duoprop
by ian h » 13 Jan 2022, 20:07
Measurements as below
Inner 52.8
Outer 57.3
Slots are
6.00 approx as they not all the same
by 14.8 BUT they are rounded at the bottom
from Keypart website it is suitable for these. does not look like it will fit yours
DP-H
DPH-BP
DPH-A
DPH-B
DPH-C
DPH-D
DPH-D1
DP-H
DPH-BP
DPH-A
DPH-B
DPH-C
DPH-D
DPH-D1
DPH-E
DPH-E
DPI-A
DPI-A
by argonaut » 27 Jan 2022, 15:13
Didn't hear back from Ian H ... so I made one ..... bit of 50mm pipe and turned to make it same size, and some hacksaw & filing to create the slots.
Welded a 30mm nut on back ... so same size as nut on the rear prop.
by ian h » 27 Jan 2022, 19:06
argonaut wrote:Didn't hear back from Ian H ... so I made one ..... bit of 50mm pipe and turned to make it same size, and some hacksaw & filing to create the slots.
I did reply with Measurements as they are on the post above yours and sent PM advising where they were.
Did not see any other messages form you so assumed it would not fit,
strange
by Ianfs » 28 Jan 2022, 10:06
Inner 52.8
Outer 57.3
Slots are
Yep, he definitely replied! :)
I'm worried now that the forum may be playing up and his post didn't show. :?
