It is currently 18 Apr 2026, 11:47
Straps
by argonaut » 22 Jun 2020, 12:08
I needed something a bit specific to tie-down my new boat.
Standard 1 piece long 5omm 5tonne straps had the strap going over gimbal housing, did not like that idea.
I wanted 2 vertical short straps .... but the 50mm ones the ratchet was too wide and fouled on the swim platform support.
25mm straps would work but not heavy enough rating.
I tried 38mm straps ... but the fixed (leading potion of strap was 300mm, and that ended up with ratchet right on edge of the transom to hull corner - so no good.
Found a manufacturer who would make me 38mm 2-tonne straps but with only 200mm leading strap (to hook) .... thought I was going to get stung on custom manufacture cost ....... not so £4.95 per strap .... the standard length ones were £5.99 !!!
Not only that they made them delivered to my door in 48 Hrs.
So if you need ratchet straps, standard or custom ...... try ARINSDALE : http://www.arinsdale.com/products.aspx?Categories=1
Customer Service: sales@ukratchetstraps.com
Arinsdale
Block 6, West Mains Ind. Est.
Grangemouth, UK, FK3 8YE
Phone: + 44 (0) 1324 665 234
Fax: +44 (0) 1324 665 388
  • In total there are 51 users online :: 1 registered, 0 hidden and 50 guests (based on users active over the past 5 minutes)
  • Users browsing this forum: Bing [Bot] and 50 guests
