It is currently 13 Sep 2025, 13:26
  • In total there are 108 users online :: 1 registered, 0 hidden and 107 guests (based on users active over the past 5 minutes)
  • Users browsing this forum: Google Adsense [Bot] and 107 guests
Mercruiser block
by Scatty257 » 19 Mar 2020, 13:29
Hi not sure if I'm listing in the right spot, I have a 1989 searay now ride that requires a block it's a 4.3 mercruiser it's the pre vortex engine if anyone can help it would be much appreciated,
Regards
Stuart
Scatty257
by ChrisH » 19 Mar 2020, 16:55
Try Tom Parker of TompaMarine
he is well connected, and may know of one, or where to get the best price.
https://www.tompamarine.co.uk/contact/
Call or text his mobile phone. He can be hard to get hold of.
by shibbs » 20 Mar 2020, 13:56
Scatty257 wrote:Hi not sure if I'm listing in the right spot, I have a 1989 searay now ride that requires a block it's a 4.3 mercruiser it's the pre vortex engine if anyone can help it would be much appreciated,
Regards
Stuart
Is the old block damaged? Might be worth considering a recon exchange? Depends on what your budget is really..
( just amended, auto correct had me over again)
by Ianfs » 21 Mar 2020, 19:17
Hi Scatty, I'm guessing you are trying to find someone who has a block for sale rather than help trying to source one?
I've heard that if a crack is not too bad, welding can sometimes work, depending upon where the damage is.
by Scatty257 » 21 Mar 2020, 19:22
Hi thanks for help so far, yes I'm trying to source a replacement block, in case it cannot be fixed, iv just had my heads done and upgraded the Carb from 2 barrel to a 4barrel
On another note I do have a inlet and Carb available
Scatty257
by shibbs » 23 Mar 2020, 23:13
Scatty257 wrote:Hi thanks for help so far, yes I'm trying to source a replacement block, in case it cannot be fixed, iv just had my heads done and upgraded the Carb from 2 barrel to a 4barrel
What was the damage? have you looked into the option of repairs..? What have you had done to the heads? I only ask, as i've just been through a possible similar situation where i kept getting problems with heads due to age and salt water corrosion, it finally came down to a replacement engine for me as it simply wasn't financially worth keep chasing the problem. Just in my opinion worth a thought before putting to much money into continued reparis.
by Bigplumbs » 30 Mar 2020, 16:44
Have you looked at repower marine
