It is currently 16 Apr 2026, 00:30
Sorento
by argonaut » 05 May 2015, 17:08
I will never buy a car with DMF for towing again.
I also had a Frontera (assume they no longer sell them) they had a good low ratio ....
by Carl » 05 May 2015, 17:47
They stopped making them back in 2004 .... and replaced it with the absolutely awful "Antera"
by _Ed_ » 06 May 2015, 10:06
argonaut wrote:The ONLY symptom was severe smell of burning every time I recovered boat or reversed up drive.
Yep exactly as I thought. The friction disc overheated. Two reasons - the dual mass has a much smaller over all mass than a single so heats up much quicker, and also by the sounds of it the fiction disc was too small for the job, and thus itself was overloaded/heated up to fast.
You were right to avoid since it was probably wearing at 10-20x its normal rate when working that hot. You can kill them in short order.
by argonaut » 06 May 2015, 10:41
Its a pity as other than that I really like Sorento ... towed perfectly apart form the 2 issues ... great on normals roads, engine had loads of torque.
JEEP, Range Rover & LandRover both made sensible choice and installed the 9 Speed ZF ..... and all the 'luxury' brands are also installing this box.
If KIA had done so I would have stayed with KIA.
by Ianfs » 06 May 2015, 12:05
Interestingly enough a lot of Discovery 2 auto owners have changed their gearboxes after failure to an Ashcroft conversion which has a heavt duty torque converter. The difference is actually quite surprising and you'd wonder why LR didn't fit it in the first place.
by _Ed_ » 07 May 2015, 00:35
This is all why I love my shogun, drives like a normal car built like a tank where it matters. Transmission is one thing (touch wood) that I'll never have to be concerned about.
by betty boop » 07 May 2015, 08:16
excuse my silly question but is that on auto's only? only I had the same on the passat 6 speed TDi manual and wondered what is was
by argonaut » 07 May 2015, 11:29
by Ianfs » 07 May 2015, 20:47
Not sure what you're referring to Ian?
by _Ed_ » 07 May 2015, 22:40
betty boop wrote:excuse my silly question but is that on auto's only? only I had the same on the passat 6 speed TDi manual and wondered what is was
Dual mass flywheels are manual only. And much more common in diesels.
