Moorings in Soton...
by Ianfs » 03 May 2016, 13:18
A few conversations going on about Kemps Quay and its tidal aspects.
Looks like a great place, I'm guessing that some of the pontoons dry out and the more expensive ones mid river are OK, so similar to Eastlands at the top of the Hamble?
by ColinR » 03 May 2016, 13:35
I think it is only the outer pontoon that stays afloat. The closer in you get the cheaper, but the narrower the tidal window
by Ianfs » 03 May 2016, 14:39
Thanks Colin, just looked at a map of their mooring and see what you mean.
by ian h » 03 May 2016, 18:50
Shamrock Quay do like a summer trailer package,
Boat is placed in the Water Friday - Monday then kept on trailer during the week, - May be worth asking about
by ChrisH » 03 May 2016, 21:10
Kemps. They tell me that on J pontoon with 1/2 M draft I should have access 2 ish hours either side of low tide
We will see how it goes this season
by Ianfs » 04 May 2016, 01:50
That's about a 5hr window. I did read that if you return at low tide though, you can moor onto a deep water pontoon and they'll put her back for you. Not bad, good service.
by ColinR » 04 May 2016, 07:21
ChrisH wrote:Kemps. They tell me that on J pontoon with 1/2 M draft I should have access 2 ish hours either side of low tide
That sounds about right although we did come back once and ran aground about 2m short of the pontoon :lol: :lol:
by ChrisH » 04 May 2016, 18:16
Ian. Yep not great but better than I have at Trafalgar . And I have to launch and recover. Just hope the drive on dock works. Think the rollers will need some work and need to get the set up right.
As mentioned elsewhere. Everything boaty is step by step. 3.8m zodiac to 4.5m Ranieri on trailer to 6.1m Mariah on trailer to first mooring. More money each time. It's feeling expensive relatively speaking now.
by ChrisH » 06 May 2016, 19:42
Ian. I think they charge to tow your boat back to the pontoon. I'll have to double check that one though
