Mercury 115 2 stroke issue
by Bigplumbs » 05 Feb 2015, 18:01
Hello all
Now I hope one of you clever chaps can help me
Last season my Mercury 115 hp 2 stroke was working well but occasionally in the early part of an outing at flat out it would hiccup and faulter a few times. After a short while it was fine and it generally did not do it again that outing.
On the last run out however at full power the engine momentarily died, all the dials went to full deflection and then returned to zero again. The engine then fired back to full power and was fine for the rest of the outing.
The radio and all other electrical items shut off during the short time (seconds) of the problem.
Other than a poor battery connection any of you clever chaps got any ideas what the problem might be
Regards
by _Ed_ » 05 Feb 2015, 23:28
Hi Dennis, not enough information. What year/model/serial number is this?
by Bigplumbs » 06 Feb 2015, 08:09
Its a mercury 115 2 Stroke 4 Cylinder 2 + 2 Year 1997 Model number says 1-115412TB Serial Number says 09969351
by mlines » 06 Feb 2015, 08:28
ALthough it never affected the engine, when our dials flicked to full on it was an earthing problem rather than a supply problem
by Bigplumbs » 08 Feb 2015, 08:12
With a large 2 stroke outboard if you start the engine then disconnect the battery does it keep running ?
  • In total there are 28 users online :: 0 registered, 0 hidden and 28 guests (based on users active over the past 5 minutes)
  • Users browsing this forum: No registered users and 28 guests
