Fuel consumption
by argonaut » 21 Oct 2020, 10:31
Hi .... going to winterize my Volvo 4.3L V6 280-C
Volvo service details require that I need to run a 2-stroke mix through it at 1500 rpm for 15 minutes.
Does anybody have an idea of how much fuel that is likely to be ? ........ I will need to source a fuel tank and mix the fuel .... don't want to prepare more than is needed as no other use for 2-stroke.
by Ianfs » 24 Oct 2020, 18:34
Haven't got a clue, but is there any way in which to connect an external tank to the fuel line between the fuel filter and the tank?
by argonaut » 24 Oct 2020, 21:48
Had the figure from US, it’s just under a US gal.
So pulling fuel feed off fuel pump, connect up a length of hose and stick in a 5L container and I’m sorted.
by Ianfs » 25 Oct 2020, 21:36
Suoerb. :D
  • In total there are 24 users online :: 0 registered, 0 hidden and 24 guests (based on users active over the past 5 minutes)
  • Users browsing this forum: No registered users and 24 guests
