Fitting gauge in the dash
by argonaut » 16 Jun 2020, 10:37
I have a dash on a boat, in centre of dash is an oddment tray ... for sunglasses etc.
This is the only free location to fit a 3'5" gauge.
The back of this tray slopes away ... so if I just drilled 3.5" hole the gauge display would not be able to be read.
Pic of dash is here .... https://flic.kr/p/2jcmEfB
My initial though is that I need to make some form of wedge mount, that would make gauge face vertical ...
see my sketch: https://flic.kr/p/2jcpbFA
Alternative options ...
Cut all the back off the oddment tray and fix a flat backplate to it ..... anyone know of a source of quality plastic (nylon ?)
Machining off the back neatly maybe not be easy (unless you know of companies who do this sort of work)
Remove oddment tray entirely and fit a flat blanking plate (might be easiest for fitting)
I guess I could manufacture out of ally sheet ... would need to have some good finish applied (maybe carbon effect foil?)
Suggestions? anybody know of a place that makes prototypes / one off's
by Ianfs » 17 Jun 2020, 10:41
Hi Argonaut,
The only place I know is a large composite fabrication place in Poole called Norco.... They built a one off boat which I nearly bought a few years ago.
https://www.norco.co.uk/
Or this place which I don't know but have heard of and they are local to me in Christchurch, Dorset. They may be able to do something by mail order.
http://allaspectsfibreglassing.co.uk/welcome/4578754410
by argonaut » 17 Jun 2020, 11:00
Thinking of a simpler approach ..... removing oddment tray (which is really a blanking plate when you don't buy SatNav
Make up a neat flat cover plate ... maybe acrylic or polypropylene, match-fixing holes, make corners neat etc, and then have whole thing Water Transfer printed (like they do on cars) and give it carbon fibre finish .....might be neatest solution.
by Ianfs » 20 Jun 2020, 17:51
Sounds like a plan. :)
