It is currently 13 Sep 2026, 21:59
Seasons not over yet
by argonaut » 16 Sep 2019, 19:51
Had a great Saturday evening out in the bay.
Keep going - it's not over yet
by shibbs » 17 Sep 2019, 06:14
:D
by ChrisH » 03 Oct 2019, 18:29
Been broken for the last 2 months. Lack of power. Eventually had new turbo installed after much investigation , quick test on the itchen last weekend .. shhh dont tell.. looks like problem is resolved. Full test this Saturday.
Sent from my SM-G960F using Tapatalk
by Ianfs » 04 Oct 2019, 08:04
Great photo Argonaut.
Good luck Chris I hope it's all ok.
by shibbs » 04 Oct 2019, 20:07
My season is. Awaiting new engine to be fitted. Over heated due to blocked intake on the leg, picked up a piece of plastic and over heated the engine, major internal damage so easiest and most economical option is a new block and too ends.
Didn’t have a bad season up until then.
by ChrisH » 04 Oct 2019, 20:26
shibbs wrote:My season is. Awaiting new engine to be fitted. Over heated due to blocked intake on the leg, picked up a piece of plastic and over heated the engine, major internal damage so easiest and most economical option is a new block and too ends.
Omg that's awful. Thought my turbo was bad enough.. no alarm ?
Have to say my alarm does not work. Just the warning light.
by shibbs » 04 Oct 2019, 20:49
No, no alarm or warning light. Just gauge which I wasn’t paying enough attention to. First I knew of it was when it started to feel lumpy, looked down and saw gauges , cut then engine straight away but was too late, was very very hot.
by ChrisH » 04 Oct 2019, 21:36
shibbs wrote:No, no alarm or warning light. Just gauge which I wasn’t paying enough attention to. First I knew of it was when it started to feel lumpy, looked down and saw gauges , cut then engine straight away but was too late, was very very hot.
Bummer. Sorry to hear that.
Had mine lifted during the investigations, got an airlock when went back in and overheated. Lucky was only in Itchen river, so seems I caught it in time.
by Ianfs » 05 Oct 2019, 09:55
Oh gosh Shibbs, that's aweful. On the bright side at least you'll get many good reasons now with a new engine.
Are you going for a block, crank and posting (short block ) and change over peripherals yourself?
  • In total there are 25 users online :: 0 registered, 0 hidden and 25 guests (based on users active over the past 5 minutes)
  • Users browsing this forum: No registered users and 25 guests
