It is currently 21 Jun 2026, 12:04
Recommendation for fuel transfer pump
by Stevie101 » 25 Sep 2016, 20:43
I use one of these. https://www.ebay.co.uk/itm/391212942947
It emptys a 20L can in 2/3 mins and you don't spill any.
If it's got Tyres, Tits or goes on the water it's going to be expensive
Stevie101
by betty boop » 26 Sep 2016, 08:29
Octobver issue of Practical boat owner showed how to build a small pump from ebay bit n bobs for £10 - looks like the small 12v option to save you working to hard at pumping/sucking/siphoning.
by ChrisH » 26 Sep 2016, 17:41
betty boop wrote:Octobver issue of Practical boat owner showed how to build a small pump from ebay bit n bobs for £10 - looks like the small 12v option to save you working to hard at pumping/sucking/siphoning.
Like. Thanks
by Matt13 » 26 Sep 2016, 20:20
I bought one of those from the boat show a few years ago it's great, takes about 3-4 mins to empty a 20l can.
Make sure the end of the pipe will fit into the can as one of the ones I bought didn't.
Matt13
by ChrisH » 27 Sep 2016, 18:14
Matt13 wrote:I bought one of those from the boat show a few years ago it's great, takes about 3-4 mins to empty a 20l can.
by Ianfs » 02 Oct 2016, 15:47
How did you get on Chris, did you buy anything?
by ChrisH » 02 Oct 2016, 22:15
Ianfs wrote:How did you get on Chris, did you buy anything?
Not yet. But might try one of the syphon pumps Stevie101 posted.
Stevie101 wrote:I use one of these. https://www.ebay.co.uk/itm/391212942947
by ChrisH » 02 Oct 2016, 22:16
Not yet Ian. But might try one of the Syphon pumps Stevie101 posted.
by argonaut » 04 Oct 2016, 11:20
Sort of returning to the OP
Siphons don't work up hill ....... would be good to know of a pump that will transfer fuel to my boat when it is on trailer ... I use 20L containers ... but they are heavy to hold above your shoulders .. and the filler spouts air lock as they are emptying so flow rate is slow.
Can't use a funnel as filler is on vertical surface, tried the flexy spout funnels ... no good as you can't hold that upright at same time as holding 20 L can.
by ColinR » 04 Oct 2016, 11:42
I have two jiggle tubes, the larger one will shift a 20ltr jerry can in under 2 mins, more like 1.
Bought one from the guy at the boat show and the other (cheaper) at Beaulieu boat jumble.
