Alpha 1 Trim Cylinder Anodes
by sprocker » 15 Apr 2015, 11:36
Can anyone advise the best way to change the anodes on the Trim Cylinders on an Alpha1 Gen2?
Can you gain access by trimming the outleg up, or do you have to disconnect the ram end from the outleg?
by mlines » 15 Apr 2015, 13:26
Mine just unscrewed and lifted off (one was difficult - corrosion)
by sprocker » 15 Apr 2015, 13:42
OK thankyou for confirming my thoughts.
I had seen a video on U-Tube where the chap had disconnected the trim cylinders to change the anodes and I couldn't understand why.
