warning buzzers
by betty boop » 19 Jun 2017, 10:46
Im looking for help on causes of 2 beeps every 60 seconds on the merc 4.3 mpi warning system - we had the boat on the river all weekend with no issues. had her running for 30 mins returning home and after a short stop at a lock the alarm started when we restarted. all gauges are reading OK lubes /oil too. literally just came on with no real changes in circumstances. the only thing I was thinking may have changed is the volts drop a bit when trim switch pressed with a dip in revs - I cant say it happened before but you never know.
by Ianfs » 19 Jun 2017, 19:56
Not sure if this is any help Ian, but repeated beeps are soft alarms. Continuous beep is a hard alarm.
You'll need to have a plug it in to be able to read the fault though, it could be a number of things.
by betty boop » 20 Jun 2017, 07:08
thanks Ian, Im guessing it wont be one of those cheap plug in ECU readers you get from Argos? :roll: with any luck it will go as quick as it came next time I start her up
